arul999
Jul 04, 2020Aspirant
Shares missing in Readynas admin page
Hi, need some help here... I logged into the Readynas admin page and noticed that my shares were missing the “shares” tab. Instead I only see “ Home folders” folder which has nothing in there. The ...
Sandshark
Jul 04, 2020Sensei
Do you normally access the files in another way? If so, do you still have access? Are you comfortable with the Linux CLI via SSH?
There is a script available that might fix your situation, but we need to make sure of the current condition of the files and shares to be sure it's the right fix for you.
arul999
I normally access the folder in windows explorer. They are not showing up in there as well. Can see the home folder only.
Yeah, I’m ok with ssh.
- StephenBJul 04, 2020Guru - Experienced User
Start by enabling it in system->settings->services. Log in as root, using the nas admin password.
First see if the shares and files are present in your data volume (default is /data ).
- arul999Jul 04, 2020AspirantI managed to view the folders in ssh, they are appearing there.
- StephenBJul 05, 2020Guru - Experienced User
arul999 wrote:
I managed to view the folders in ssh, they are appearing there.Good. The next step is to double-check that the OS partition isn't full.
Enter
# df / -h # df / -i
If you have no apps installed, the first command should show about 20% usage, the second should show about 2%. If you are getting high utilitization (more than 80%), then we should take care of that before you run the script to rebuild the shares list.
Once you've confirmed that you have good free space on the OS partition: the script that Sandshark is talking about is located here.
