arul999
Jul 04, 2020Aspirant
Shares missing in Readynas admin page
Hi, need some help here... I logged into the Readynas admin page and noticed that my shares were missing the “shares” tab. Instead I only see “ Home folders” folder which has nothing in there. The ...
arul999
I normally access the folder in windows explorer. They are not showing up in there as well. Can see the home folder only.
Yeah, I’m ok with ssh.
Jul 04, 2020Guru - Experienced User
Start by enabling it in system->settings->services. Log in as root, using the nas admin password.
First see if the shares and files are present in your data volume (default is /data ).
- arul999Jul 04, 2020AspirantI managed to view the folders in ssh, they are appearing there.
- StephenBJul 05, 2020Guru - Experienced User
arul999 wrote:
I managed to view the folders in ssh, they are appearing there.Good. The next step is to double-check that the OS partition isn't full.
Enter
# df / -h # df / -i
If you have no apps installed, the first command should show about 20% usage, the second should show about 2%. If you are getting high utilitization (more than 80%), then we should take care of that before you run the script to rebuild the shares list.
Once you've confirmed that you have good free space on the OS partition: the script that Sandshark is talking about is located here.
- arul999Jul 05, 2020AspirantThanks. Where’s the link to the script and how to run it?
