Gadgetman79
Feb 28, 2019Aspirant
Shares/Volumes not detected on ReadyCloud since upgrading firmware
I recently bought this NAS device in hopes for easy setup and use but having nothing but issue even thought I followed the direction via the setup video. It is not working as shown in the video.
Gadgetman79
Can't tell if its a NAS issue or Ready cloud, as I can see the device in Ready Cloud and I see the drive 1 & 2 lit up on the NAS but according to the ready cloud site, it says it has no shares or volumes nor can I access the admin page. I tried to install raidar but got an hard stop error message saying it wont let me as I need to install java or something.
Ok I will try the phone support when I get home tonight, as a last ditch effort. But there is a very high probability that I will return this device, for a drobo, which I have used in the past and was very simple to use.
Feb 28, 2019Guru - Experienced User
Try accessing the NAS directly when you are at home.
https://nas-ip-address/admin should get you to the web admin interface (using the actual ip address of course). You'll need to click through the security warnings, and then you should see the username/password prompt.
You can also try accessing the NAS from file explorer (windows) and finder (mac). For windows, enter \\nas-ip-address in the file explorer address bar. Be careful on the slash direction.
- Gadgetman79Feb 28, 2019Aspirant
HI Stephen,
Unfortunately, I have already tried to access the NAS directly and also by file explorer. I even tried to reset to factory default to reformat everything but none of that worked. I will try the link to admin page with the NAS ip address again as I call support.
- StephenBFeb 28, 2019Guru - Experienced User
Perhaps install RAIDar 6.5 (installing Java if it needs you too). That can query the NAS status over your network, and will give you more information on what's going on.
