Madmax1963
Feb 22, 2016Aspirant
Sharing folders remotely with friends
I would like to know if there is a way to share folders and or files with friends by sending them a link and not having them join Readycloud. Thanks in advance, Madmax1963
- Feb 22, 2016
Hi Madmax1963,
It is possible. Just log in your ReadyCLOUD admin user, select the share/folder and select the "Share button".
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team
mdgm-ntgr
Feb 22, 2016NETGEAR Employee Retired
Yes. We added the ability to share a link to a folder in 6.4.0. I believe this could already be done for files on older firmware.
- Madmax1963Feb 22, 2016Aspirant
Thank you for your reply ! I'm very happy to hear that. I Imagine that I would need to have readycloud installed on my end so I can send the link to the file or folder to my friend via email right?
- BrianL2Feb 22, 2016NETGEAR Employee Retired
Hi Madmax1963,
Hope this helps!
Kind regards,
BrianL
NETGEAR Community Team- Madmax1963Feb 22, 2016Aspirant
Excellent, thank you !!!!!!!
