Retired_Member
Feb 25, 2014Should i buy WD Red for my NAS or normal drives ?
I own two ReadyNas 4 Pro and i'm about to upgrade my drives to 4tb. Now i need to decide if i take WD Red drives or just go with the Seagate 4TB which is almost $50 cheaper. Is there any reason why...
mdgm-ntgr
Feb 25, 2014NETGEAR Employee Retired
I find retailers often advertise 1 year warranties for products such as this without bothering to check whether the warranty is longer. I would go with what the manufacturer says the warranty is.
When you bought your Pro 4 you may have bought it from a reseller which said it had a 1 year warranty, when in fact the Pro 4 has a 5 year warranty.
