captainhaddock
Jul 05, 2012Aspirant
Should WD20EARS be removed from the HW Compatibility Lists
Am not impressed with my wasted disks purchase from the HW Compatibility List. After checking the list, I went for 2 x Western Digital 2TB WD20EARS hard drives for my Duo. http://kb.netgear.com/app/an...
mdgm-ntgr
Oct 13, 2012NETGEAR Employee Retired
What version of RAIDiator are you running Wizball. Those 42 ATA Errors could be due to running 4.1.6 or earlier with those drives installed at some point. There was an issue where the ATA error count would increase by 6.
Most likely one or more of the disks is failing/dead. Best to power down, remove the disks, connect them to an internal SATA port in your PC and check them using WD LifeGuard Diagnostics: http://www.readynas.com/kb/faq/hardware/how_can_i_verify_that_my_disk_is_bad
