Platypus69's avatar
Platypus69
Luminary
Aug 13, 2020
SIMPLE: Does a "factory reset" ALSO perform a "OS reinstall"
Apologies, but it is not clear from support URL below whether a Factory Default (2) process also performs a OS Reinstall (3).
From https://kb.netgear.com/20898/ReadyNAS-ReadyDATA-Boot-Menu
"Your storage system has the following boot modes:
  1. Normal. Initiates a normal boot process, just like booting using the Power button.
  2. Factory default.
    WARNING: The factory default reboot process resets the unit to factory settings, erases all data, resets all defaults, and reformats the disk to X-RAID.
  3. OS reinstall. Reinstalls the firmware from the internal flash memory to the disks. The OS reinstall boot mode can be useful when the system crashes and corrupts some configuration files. OS reinstall boot mode also resets some settings on your unit, such as Internet protocol settings and the administrator password, to defaults.
  4. Tech support.
  5. Skip volume check. (RAIDiator only)After a system crash, the system tries to scan and fix the volume using a file system check. If several problems are found on a disk, this process can stall, causing the system not to boot. You can use this option to skip the scan and let the system boot.
  6. Memory test. Performs a memory test. The pass or fail result is reported using the unit's LEDs. Contact NETGEAR Support to interpret memory test results.
  7. Disk test. Performs an offline full disk test. This can take 4 hours or more, depending on the size of your disks. Any problems are reported in the RAIDar discovery tool."
  • StephenB's avatar
    The NAS boots from the disks, and the factory default installs the OS on the disks after it formats them. Of course the Factory Default will destroy all data and settings too.
    That's not quite the same as the OS reinstall, though it is similar.  The OS reinstall won't uninstall apps for instance.
    • Platypus69's avatar
      Platypus69
      Luminary
      Thanks.
      I have "inherited" a decommissioned, out of warranty, diskess RN316.
      So I just wanted to wipe it completely and put in some old 4TB disks that I have are lying around doing nothing. So use this RN316 to store data that I can afford to lose.
      So I just wanted to make sure I clean up everything as besy as I can, do not want any residual firmware , updates, config, logs, etc.
      So the plan was to to a Factory rest and then a memory check. But I was interested in whether i should also lay down a brand new 6.10.3 OS, but it seems the factory reset process does that after it formats the disks.
      Thanks again.
      • Sandshark's avatar
        Sandshark
        Sensei
        If you got the NAS diskless, it is already "wiped".  No user or configuration data is stored in flash memory, it's all on the drives.
ProSupport for Business
