kevinngeorgia
Jan 13, 2012Aspirant
Sliding Rails for 3100
I'm about to replace a 1100 with a 3100 but don't know if it uses the same rackmount sliding rails. I can't find any specific rails for the 3100... Thanks for any help, Kevin
mdgm-ntgr
Jan 13, 2012NETGEAR Employee Retired
"Optional spare part" i.e. spare part you can purchase to replace what is included in the package if it fails. Some people like to have a spare part on hand to minimise downtime. Sliding rails are not a component that's likely to fail so unless you're managing a huge number of units you're unlikely to want a spare.
