YE7
May 24, 2017Aspirant
SMB disabled
Hi, I have upgraded the firmware on a RN42200 from 6.7.1 to 6.7.3 and that caused it to loose SMB service. When I click on SMB service to enable it, I hit apply and nothing happens. Thanks, ...
mdgm-ntgr
May 25, 2017NETGEAR Employee Retired
What error messages do the logs show regarding the SMB service?
YE7
May 25, 2017Aspirant
I am not seeing anything regarding SMB in the logs.
- hungerJun 02, 2017Apprentice
I'm running 6.6.1 on a 3138 and have the same symptoms.
When I run dmesg I get tons of messages like:
[ 622.344974] systemd-journald[1419]: Failed to rotate /var/log/journal/2d37aed0a2c3473893d14ce66fdb2e83/system.journal: No space left on device
[ 622.345351] systemd-journald[1419]: Failed to write entry (25 items, 603 bytes), ignoring: Input/output error
[ 622.527176] systemd-journald[1419]: Failed to rotate /var/log/journal/2d37aed0a2c3473893d14ce66fdb2e83/system.journal: No space left on device
[ 622.527477] systemd-journald[1419]: Failed to write entry (23 items, 537 bytes), ignoring: Input/output error
[ 622.731857] systemd-journald[1419]: Failed to rotate /var/log/journal/2d37aed0a2c3473893d14ce66fdb2e83/system.journal: No space left on device
[ 622.732220] systemd-journald[1419]: Failed to write entry (23 items, 552 bytes), ignoring: Input/output error
[ 623.043381] systemd-journald[1419]: Failed to rotate /var/log/journal/2d37aed0a2c3473893d14ce66fdb2e83/system.journal: No space left on device
[ 623.043700] systemd-journald[1419]: Failed to write entry (20 items, 484 bytes), ignoring: Input/output error
It appears there is plenty of free space:
$ df -h /var
Filesystem Size Used Avail Use% Mounted on
/dev/md0 4.0G 2.0G 2.1G 49% /- mdgm-ntgrJun 03, 2017NETGEAR Employee Retired
# btrfs fi show # btrfs fi df /
- hungerJun 10, 2017Apprentice
# btrfs fi show
Label: '0a435410:root' uuid: 33bedd30-c5b0-4104-9ec5-4f3ba31257ba
Total devices 1 FS bytes used 1.63GiB
devid 1 size 4.00GiB used 4.00GiB path /dev/md0
Label: '0a435410:data' uuid: 1737dc88-5be7-433f-9b84-36dfb9879282
Total devices 1 FS bytes used 21.91TiB
devid 1 size 27.27TiB used 24.57TiB path /dev/md127
# btrfs fi df /
Data, single: total=3.57GiB, used=1.48GiB
System, DUP: total=8.00MiB, used=16.00KiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=204.56MiB, used=154.78MiB
Metadata, single: total=8.00MiB, used=0.00B
GlobalReserve, single: total=48.00MiB, used=0.00B
