Sp4
Feb 14, 2021Guide
SMB Protocol 3.1.1 and Windows 10
https://kb.netgear.com/24913/How-do-I-back-up-my-Windows-PC-to-a-ReadyNAS-OS-6-system-using-Windows-Backup-and-Restore I'm refrencing this article to lower the SMB version to 2.0 for Windows Back...
- Feb 15, 2021
I believe it was true back in 2016, but I suspect Microsoft resolved the issue after that.
I suggest just trying the backup with SMB 3.1.1, and see if it works.
Feb 15, 2021Guru - Experienced User
Sp4
Feb 15, 2021Guide
Yes it worked just fine. I'm assuming if it didn't I would have gotten a connection error? I was more worried about the data being corrupt. I downloaded the newest manual and it somewhat differs from that older article. Thanks for your response StephenB
- StephenBFeb 16, 2021Guru - Experienced User
The backup would have failed - not sure what the error would be.
Thanks for posting back, it's good to know that workaround is no longer needed.
JohnCM_S , Marc_V - It looks like this article needs some updating: https://kb.netgear.com/24913/How-do-I-back-up-my-Windows-PC-to-a-ReadyNAS-OS-6-system-using-Windows-Backup-and-Restore
- rn_enthusiastFeb 16, 2021Virtuoso
By the way, if you want to see what SMB version the client is opting to use, then you can see it by running this command from the CLI of the NAS - while the client is connected over SMB.
# smbstatus
Quite handy!
Or for the brief version:
# smbstatus -b
For all options available:
# smbstatus --help
