GiGa1
Aug 18, 2011Aspirant
[Solved] Replacing disk failed...
My Readynas NV have 4 Seagate ST3320620AS 7200.10... after severeal years of good job, the disk 2 gone dead... Ok, no problem... I've another Seagate (the same type) on pc, which works fine, and I co...
PapaBear1
Aug 18, 2011Apprentice
Did you insert the disk when the system was off or when it was on?
