GiGa1
Aug 18, 2011Aspirant
[Solved] Replacing disk failed...
My Readynas NV have 4 Seagate ST3320620AS 7200.10... after severeal years of good job, the disk 2 gone dead... Ok, no problem... I've another Seagate (the same type) on pc, which works fine, and I co...
PapaBear1
Aug 18, 2011Apprentice
If the disk had data, it is best to hot add (add while system is on). Of course the best option would be to hook it up to a PC and wipe the disk before adding, which you did.
Since you had Seagate for Dos, run the tests and make sure the drive is reporting properly. I just have had problems with two ST31000528AS drives in my NV+ when they reported only 32MB of space vs the 1TB they are supposed to. I reset the capacity with SeaTools for DOS. I am in the process of erasing the disks completely.
I would boot the NV without the disk present and after it is stable, hot add the disk. If that does not work, post back.
