GiGa1
Aug 18, 2011Aspirant
[Solved] Replacing disk failed...
My Readynas NV have 4 Seagate ST3320620AS 7200.10... after severeal years of good job, the disk 2 gone dead... Ok, no problem... I've another Seagate (the same type) on pc, which works fine, and I co...
GiGa1
Aug 19, 2011Aspirant
I've donwloaded logs... on "disk_smart.log" I see:
and on xraid_config.log, I see:
What is "r_size"? Why on new drive is 2113 (625121968-625119855) small then other disks?
In other disks, "size"="r_size" but on new Seagate "r_size"<"size"
Could be the problem?
=== START OF INFORMATION SECTION ===
Device Model: [No Information Found]
Serial Number: [No Information Found]
Firmware Version: [No Information Found]
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 1
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Fri Aug 19 11:35:07 2011 CEST
SMART is only available in ATA Version 3 Revision 3 or greater.
We will try to proceed in spite of this.
SMART support is: Ambiguous - ATA IDENTIFY DEVICE words 82-83 don't show if SMART supported.
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
PHYSICAL_DRIVE:0:number=0,device=hdc,major=22,minor=0,raid_id=0,state=online,present=1,size=625121968,r_model=ST3320620AS,r_size=625121968,r_fw=3.AAD
PHYSICAL_DRIVE:1:number=1,device=hde,major=33,minor=0,raid_id=1,state=faulty,present=1,size=625121968,r_model=ST3320620AS,r_size=625119855,r_fw=3.AAK
PHYSICAL_DRIVE:2:number=2,device=hdg,major=34,minor=0,raid_id=2,state=online,present=1,size=625121968,r_model=ST3320620AS,r_size=625121968,r_fw=3.AAD
PHYSICAL_DRIVE:3:number=3,device=hdi,major=56,minor=0,raid_id=3,state=online,present=1,size=625121968,r_model=ST3320620AS,r_size=625121968,r_fw=3.AAD
