intothevoid
Oct 01, 2012Aspirant
[Solved] Seagate ST3000DM001-9YN166: Load Cycle Count
Hi, sorry if this has been discussed already, all i could find are topics about upgrading the firmware on these drives. I've got a NV+v2 with 4 3TB ST3000DM001-9YN166 disks in it, firmware CCH4 ...
HERBIEO
Oct 15, 2012Aspirant
This is the list of known S.M.A.R.T. attributes supported by IDE and Serial ATA hard disks.
Note: some manufacturers may use the attributes for different purposes also.
Attributes not listed here are "vendor specific" attributes (their purpose is not known)
Raw Read Error Rate - Errors occured while reading raw data from a disk
Indicate problem with the disk surface or the read/write heads.
Critical attribute
Throughput Performance - General throughput performance of the hard disk
Indicate problem with motor, servo or bearings.
Spin Up Time - Time needed by spindle to spin-up to full RPM
Indicate problem with motor or bearings.
Critical attribute
Start/Stop Count - Count of start/stop cycles of spindle
This value does not directly affect the condition of the drive.
Reallocated Sector Count (Reallocated Sectors Count) - Count of sectors moved to the spare area
Critical attribute
Command Timeout - Indicates a number of aborted operations due to hard disk timeout
Critical attribute
Read Channel Margin - Margin of a channel while reading data
The exact function of this attribute is not specified.
Seek Error Rate - Rate of positioning errors of the read/write heads
Indicate problem with servo, head. High temperature can also cause this problem.
Critical attribute
Seek Time Performance - Average time of seek operations of the heads
Indicate problem with servo.
Critical attribute
Power-On Time Count - Total time the drive is powered on
The unit of the measure depends on the manufacturer.
Spin Retry Count - Retry count of spin start attempts
Indicate problem with motor, bearings or power supply.
Critical attribute
Drive Calibration Retry Count - Number of attempts to calibrate a drive
Drive Power Cycle Count - Number of complete power on/off cycles
Soft Read Error Rate - Number of software read errors
The number of uncorreactable read errors.
Airflow Temperature - Airflow temperature
The temperature of the air inside the hard disk housing.
Mechanical Shock - Count of problems caused by mechanical shock
Acceleration (for example falling) can cause mechanical shock.
Power off Retract Cycle - Count of power off cycles
Load/Unload Cycle Count - Count of load/unload cycles
Number of cycles the head moved into landing zone position.
HDD Temperature - Disk temperature
The temperature inside the hard disk housing.
Hardware ECC Recovered - Count of correctable errors
Number of errors corrected by the internal error correcting mechanism.
Reallocation Event Count - Count of sector remap operations
Number of all (successful and failed) remap operations.
Critical attribute
Current Pending Sector Count - Count of unstable sectors
These pending sectors may be remapped to the spare area.
Critical attribute
Off-Line Uncorrectable Sector Count - Count of uncorrectable errors when reading/writing
Critical attribute
Ultra ATA CRC Error Count - Count of errors during data transfer between disk and host
Indicate problem with the power supply or data cable.
Write Error Rate - Errors occured while writing raw data from a disk
Data Address Mark Errors - Number of data address mark errors
Number of incorrect or invalid address marks.
Run Out Cancel - Number of data correction errors
Invalid error correction checksum found during error correction.
Soft ECC Correction - Number of corrected data errors
Errors corrected by the internal error correction mechanism.
Thermal Asperity Rate - Number of thermal problems
Total number of problems caused by high temperature.
Flying Height - Head flying height
The height of the disk heads above the disk surface.
Spin High Current - Current value during spin up
The current needed to spin up the drive.
Spin Buzz - Number of cycles needed to spin up
The number of retries during spin up because of low current available.
Offline Seek Performance - Drive performance during offline operations
The seek performance of the drive during internal self tests.
Disk Shift - Distance of the disk has shifted relative to the spindle
Incorrect disk spin can be cause by mechanical shock or high temperature.
G-Sense Error Rate - Number of mechanical errors
Number of errors resulting from shock or vibration.
Loaded Hours - Number of powered on hours
This value is constantly increasing (once per every hour).
Load/Unload Retry Count - Number of load/unload operations
The number of drive head enters/leaves the data zone.
Load Friction - Mechanical friction rate
The rate of friction between mechanical parts. Indicate problem with the mechanical subsystem of the drive.
Load-in Time - Total time the heads are loaded
The time while the read/write heads are in the data zone.
Torque Amplification Count - Rate of torque increase
Torque increase during the spin up operation of the hard disk.
Power-off Retract Count - Number of power off cycles
The number of times the head was retracted as a result of power loss.
GMR Head Amplitude - Head positioning amplitude
Head moving distances between operations.
Hard Disk Temperature - Disk temperature
Head Flying Hours - Number of head positioning hours
Time spent during the positioning of the drive heads.
Read Error Retry Rate - Number of retries during read operations
Number of errors found during reading a sector from disk surface.
Critical attribute
Critical attribute
Critical attribute
Critical attribute
Critical attribute
Critical attribute
Critical attribute
Critical attribute
Critical attribute
Critical attribute
