intothevoid's avatar
intothevoid
[Solved] Seagate ST3000DM001-9YN166: Load Cycle Count
Hi,
sorry if this has been discussed already, all i could find are topics about upgrading the firmware on these drives.
I've got a NV+v2 with 4 3TB ST3000DM001-9YN166 disks in it, firmware CCH4 (the latest).
System has been running for a couple of months now, and all was working smoothly until i got a warning 2 weeks ago:
Detected increasing command timeouts[65537] on disk 1 [ST3000DM001-9YN166, W1F083HJ]. This often indicates an impending failure. Please be prepared to replace this disk to maintain data redundancy.
Looking into the SMART status, it indeed gives some ridiculously high number (4295032833) on command time out for disk 1. On the other 3 disks it's 0.
Another thing i noticed in the SMART status for all disks though, is that the load count cycle is quite high: around 43000 after 1800 power on hours.
After a bit of googling however, all i could find was this problem cropping up on WD green drives. The solution seems to be to set the idle time a bit higher.
I did find this old topic (http://www.readynas.com/forum/viewtopic.php?f=36&t=51536) explaining how to do it on some other seagate model, but i wanted to get some feedback before i attempt to change things via ssh. Don't wanna corrupt anything.
So basically my questions are:
1) Is the command time out problem in anyway related to the lcc problem, or is this drive just about to die no matter what?
2) Does anybody else have these high lcc numbers with the ST3000DM001 drives?
3) Is it worthwhile changing the idle time setting with hdparm?
3b) If yes, are the instructions in that old topic still valid?
On a related note, i did install the ssh add-on and looked around a little, however when i try to get drive status with hdparm i get this:
root@nas:~# hdparm -i /dev/sda
/dev/sda:
HDIO_GET_IDENTITY failed: Inappropriate ioctl for device
Same for sdb, sdc, and sdd
Am i using the right identifiers here? Sorry for the ignorance :oops:
Hope this isn't all too confusing, i tried to cram a lot of information in this post :-)
Thanks in advance for any help!
EDIT: apparently i do not have permission to use the url tag..
ProSupport for Business
