dbott67
May 30, 2008Guide
Spec Sheets and Replacement Parts
I figured that it might be a good idea to create a thread where people might be able to obtain information about Infrant-branded ReadyNAS products that may no longer be produced or for products that a...
dbott67
May 30, 2008Guide
andyv wrote: I have an X6 and need to replace Fan 3 again - we did it almost exactly a year ago. Previously, I just ordered it from the Infrant Store but since that is no more, I'm not sure where I can purchase it from. Does anyone on the board have any suggestions as to how to approach this?
Thanks,
Andy
Name Code Qty Each Options
Cross flow fan for RN06-FAN1 1 20.00
Version A ReadyNAS 600/X6
(Shipped)
I think this may do it for you:
from this thread: viewtopic.php?f=7&t=18618&start=0&st=0&sk=t&sd=a
Chocomonsters wrote: I have replaced the fan twice so far in my ReadyNas x-6 rev A. Once fan has failed and it was replaced under warranty. Second time it was out of warranty and it was making rattling noise.
I found an identical fan manufactured for Silverstone by a third party in Taiwan. I've purchased it through NewEgg. I am not sure NetGear will sanction this fan, but if your NAS is out of warranty it is an option.
You can search for SILVERSTONE RL-FX121 Case Fan ( http://www.newegg.com/Product/Product.a ... 6835220002 ).
Blessed by a Jedi:
chirpa wrote: Yes, the FX-121 from Silverstone is a suitable replacement.
