dbott67
May 30, 2008Guide
Spec Sheets and Replacement Parts
I figured that it might be a good idea to create a thread where people might be able to obtain information about Infrant-branded ReadyNAS products that may no longer be produced or for products that a...
MrCyberdude
May 27, 2009Guide
Can someone confirm that this is the same size and specs?
My concern is that it doesnt appear to have the same sata conectors!
ENP-2222F = 220W TFX 12V Power Supply; 140x85x62 mm
http://enhance-electronics.industrialpa ... -2222f.htm
Part Number:ENP-2222F
Model Number:ENP-2222F
Make:ENHANCE ELECTRONICS
Lead Time:Available
Qty In Stock:Available
================ http://www.itus.se/pdf/tfx12v/enp2220f.pdf ======OLD Version Maybe===
================ http://www.itus.se/pdf/tfx12v/enp2222f.pdf =======================
TFX 12V ENP2222F 220W
TFX 12V Compliant Passive PFC
Remote on/off Manual select switch
Protection High Output Current for +5Vsb
Short Circuit
Over Voltage Protection
UL / cUL, CB, TUV Safety approved
FCC / CE EMC Approved
High efficiency Dimension ( W x L x H ) : 85 x 140 x 62 mm
Optional Fan Speed Thermal Control
Voltage Regulation
Input Voltage 100 -127/200 - 240VAC Manual select switch
Frequency 47 ~ 63 Hz
Input Current
5A @ 115VAC
3A @ 230VAC
Hold up time 16ms@ full load
High efficiency 70% at Full Load
+5V Output ≦ 7.5V Max
+3.3V Output ≦ 4.3V Max
+12V Output ≦ 16.2V Max
Short-Circuit Protection On each channel
Environmental Specification
Operating / Storage Temp 0 ~ 40oC / -20 ~ 70oC
Relative Humidity 5 ~ 95%
Operating / Storage Altitude 10,000 / 50,000 FT
MTBF 100,000 HRS
Safety Approvals UL/CUL, CB, TUV,
Nemko
EMC Regulations FCC, CE
Apply for All Intel Processors upto P4
All AMD Processors upto Athlon
Last Update : 7/2/2003
USA OFFICE
13100 ALONDRA BLVD., UNIT 106,
CERRITOS, CA 90703
E-MAIL : [email protected]
TEL : +1 562 677 1268 FAX : +1 562 677 1269
Lead Time:Available
Short Circuit
Voltage Regulation
Minimum Maximum Peak
+3.3V +/-5% 0.3A 17A --
+5V +/-5% 0.3A 13A --
+12V +/-5% 1.0A 16A 17A
-12V +/-10% 0A 0.3A --
+5Vsb +/-5% 0A 2.0A 2.5A
* 3.3V & 5V combine load 80W
Input Current
5A @ 115VAC
3A @ 230VAC
MTBF 100,000 HRS
Nemko
USA OFFICE
CERRITOS, CA 90703
