Maxime000
Dec 21, 2011Aspirant
Specs and features for Duo v2 and NV+ v2?
Hi all, I have checked the comparison page dated November 10, 2011 http://www.readynas.com/?cat=49 and the product page http://www.netgear.com/home/products/st ... D4000.aspx and found contradict...
mdgm-ntgr
Dec 27, 2011NETGEAR Employee Retired
You can enable SSH access. See http://www.readynas.com/forum/viewtopic.php?f=36&t=59214&p=332842#p332842
NetGear has said that they plan to add more features, we'll have to wait and see what they are.
NetGear wrote:
With the EnableRootSSH add-on, you can now remote login to the ReadyNAS RAIDiator shell as a root user. Initial password for root will be the same as the current FrontView admin password. Please keep in mind that NETGEAR may deny support if you’ve enabled root access.
