anna_arun
Jul 23, 2014NETGEAR Expert
SQL DB Auto Backup
Any Inputs on how to do a SQL Data Base Backup automatically on scheduled basis (Free Software)
- chirpaLuminaryOn what model ReadyNAS?
- anna_arunNETGEAR ExpertRN314
- mdgm-ntgrNETGEAR Employee RetiredWell you could try to install something like MySQL Backup if you are comfortable with installing things via the shell or script your own backup via the shell.
- chirpaLuminaryWhoCares developer once made a MySQL Backup addon for the very old Sparc systems. Maybe something similar can be redone for OS6.
Similar request: viewtopic.php?f=153&t=76454 - fastfwdVirtuosoForgive me for asking, but I only use OS4... Doesn't OS6's MySQL package already include mysqldump?
- mh5blAspirantI think to use the Mysqldump with out a add-on, you have to have shell knowledge ?
I am still hope to get hold of a replacement add-on. to back-up my-sql databases. Would do it my-self but my knowledge is not good enough.
Anyone found one?
I am looking at this as a way to maybe go. installing it on the readyNAs website area - xeltrosApprenticeMysql dump is the way to go, not sure you can backup it automatically without shell, maybe phpmyadmin ? it lets you export the database, maybe it can schedule it (not sure).
Anyway via SQL this script was used to backup a GLPI server, it's a little old and I would advise to test it properly (though it worked perfectly for me).
I'm sorry, this was done for a french-only company so every comment is in french, I will comment if needed.
I deleted some stuff to present a clean script (it was backing up multiple databases and sending some alerts that wouldn't work on the NAS). I let you the part that saves the web files though.
the line that will help you is this one : mysqldump --user root --password=somepassword glpi > /Backups/GLPIDB/$NAME
it is saving the GLPI base as an SQL file named according to the stored value in the $NAME variable.
As already said, since the script was edited and is pretty old, you would want to test it on fake data (or with a fresh backup before testing).#!/bin/bash
#on teste si les dossiers existent
if [ ! -d /Backups/GLPIDB/ ]
then mkdir -p /Backups/GLPIDB
fi
if [ ! -d /Backups/GLPI-Files/ ]
then mkdir -p /Backups/GLPI-Files
fi
#On regarde si le log existe, si oui on supprime
if [ -e /scripts/GLPI-Backup.err ]
then rm /scripts/GLPI-Backup.err
fi
#on verifie qu'il reste de la place sur le serveur
DFREE=`df /|awk '{print $3}'|grep [0-9]`
DNEED1=`du /Backups -bc|awk '{print $1}'|tail -n 1`
DNEED=`echo "$DNEED1/4/1024"|bc`
if (( $DFREE < $DNEED ))
then
echo "Espace disque serveur GLPI [critique]" >> /scripts/GLPI-Backup.err
fi
#sauvegarde de la base GLPI
NAME=`date +"%d-%m-%y_%Hh%M"`_GLPIDB.sql
[color=#FF0000]mysqldump --user root --password=somepassword glpi > /Backups/GLPIDB/$NAME[/color]
RETURN=`echo $?`
# si OK suppression des anciens backups
if [ $RETURN = 0 ]
then
find /Backups/GLPIDB/*.sql -mtime +5 -exec rm {} \;
fi
#SI echec alors log
if [ $RETURN != 0 ]
then
echo "Sauvegarde de la base GLPI [ECHEC]" >> /scripts/GLPI-Backup.err
fi
#si deux backups sont crees dans la meme minute, le plus vieux est efface
if [ -e /Backups/GLPIDB/$NAME.bz2 ]
then rm /Backups/GLPIDB/$NAME.bz2
fi
#compression
bzip2 /Backups/GLPIDB/$NAME
FILESIZE=`du -b /Backups/GLPIDB/$NAME.bz2|awk '{print $1}'`
#on verifie que le fichier n'est pas vide (taille > 1.5M), sinon on log
if (( $FILESIZE < 1500000 ))
then
echo "Compression de la sauvegarde GLPI [ECHEC]" >> /scripts/GLPI-Backup.err
fi
#test de l'archive
bzip2 --test /Backups/GLPIDB/$NAME.bz2
RETURN=`echo $?`
#si le teste echoue ou que le fichier est trop petit on log
if [ $RETURN != 0 ]||(( $FILESIZE < 1500000 ))
then
echo "Test de la sauvegarde GLPI [ECHEC]" >> /scripts/GLPI-Backup.err
fi
#sauvegarde des documents GLPI
tar cjf /Backups/GLPI-Files/`date +"%d-%m-%y_%Hh%m"`_GLPI-FILES.tar.bz2 /var/www/html/glpi/files
RETURN=`echo $?`
#si Echec, on log
if [ $RETURN != 0 ]
then
echo "Sauvegarde des Fichiers GLPI [ECHEC]" >> /scripts/GLPI-Backup.err
fi - mh5blAspirantI am looking at this site 'www.mysqldumper.de'
looks like it may have promess.
but I think the readynas cut-down web-server my need additional files.
will keep you up-dates - mh5blAspirantSo I install this on the readynas. but there was a problem with the install and I have been told to
Check your php error log. This might be caused by missing the php-mysql extension in your php installation. - I have the add-on PHP by Poussin ( Thanks ) but does this include the php-mysql extension ?
- And how do I check the php error Logs ?
Thanks - xeltrosApprenticeI don't think that this is included. You can try apt-get install php5-mysql or you can install phpmyadmin from the web interface, I think it uses it to connect to mysql. Maybe the MySQL package installs it too. But installing those packages from the web interface will add some other unnecessary things too.
