phistrom
Jan 25, 2018Star
SSD Tier is useless on ReadyNAS 4312
What is the point of adding SSD tiering if I still cannot use the internal SATA ports on the ReadyNAS 4312X? I have to give up two of the 12 bays in this thing if I want to have a RAID 1 of SSDs for metadata caching?
Can we please get an update that enables the use of the two internal SATA ports in the frontview GUI?
PS - Why doesn't the forum let you pick the ReadyNAS 4312 as the model when posting?
- daddygrantAspirant
I completely agree. Integrating the use of the internal ports to the GUI would be a pleasant boost to the product line. I'll be a perfect place for SSD caching drives or volumes without sacrificing the capacity of the unit. QNAP, DROBO and Synology has already gone this direction with internal m.2 amd mSata ports.
It is possible to add internal SSDs for the new SSD tiering feature. Read below for how I accomplished it. I'm not going to run my NAS this way in production though because I'm worried that a future update from Netgear will break everything. I'll wait until this is an officially supported feature. But it should prove to Netgear that it's simply a matter of adding a little more logic to the GUI.
- You can have whatever RAID you want. I'm assuming you've filled all 12 slots on the 4312 with regular hard drives like you're supposed to.
- Power down your NAS. Unplug the power. Open it up. Remove the CPU fan hood to reveal the tray and 2 SATA ports.
- Remove any 2 of your hard-drives from the front bays.
- Using 2 SATA cables, connect them to the SATA ports found under the CPU fan hood. And of course, hook them up to the SATA power connectors.
- In the 2 empty bays, plug in your 2 SSDs that you want to use for metadata tiering.
- Plug in power to turn the NAS back on. You can't really close up the case. Let's move quickly so this thing doesn't get too hot.
- Using the web UI, select the two SSDs from the "Volumes" screen. Click the "Add Tier" button on the left side.
- Confirm that you have a second tier. You'll find that your two hard-drives don't show up, but the RAID is still just fine. Power down again like in step 2.
- Remove the SSDs
- Remove the hard-drives
- Put the hard-drives back in their respective bays. Plug your SSDs into the internal ports now. The tray below the CPU fan hood comes out and you can bolt 2 2.5" drives to it.
- Once everything is wired back up and looks good, close up your NAS, power it back on, and behold you still have your RAID array and also now have a RAID 1 of metadata SSDs.
Again, this is just to prove that internally, everything about this seems to be supported. It's just this Mickey Mouse Netgear web interface GUI has no idea how to display the two internal drives. Everything about the web interface seems hardwired to think there can only be 12 drives and those drives absolutely must be in the hot-swap bays in the front.
- JohnCM_SNETGEAR Employee Retired
Hi phistrom,
Thank you for sharing the following information, this would help a lot of our members.
You may also post suggestions and ideas at the Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
We appreciate your contribution to the community!
JohnCM_S
NETGEAR Community Team
