jeffhayes
Jan 03, 2011Aspirant
ST2000DL003 Compatibility?
Being a RNP user that is running out of space, I'm wanting to purchase new drives. I'm interested in using the Seagate ST2000DL003 2TB drives. These drives are not currently listed on the compatib...
mdgm-ntgr
Jan 18, 2011NETGEAR Employee Retired
It takes time for NetGear to test drives thoroughly and if necessary work on compatibility fixes and retest drives. NetGear will update the compatibility list when they are satisfied that drives are compatible and not before. Also note, that NetGear has to wait for drives to appear on the market, then as supply improves buy a large quantity of the disks (need lots of drives to test allowing for disk failures and testing on multiple units) so it can take a while before disks are able to be added.
