jeffhayes
Jan 03, 2011Aspirant
ST2000DL003 Compatibility?
Being a RNP user that is running out of space, I'm wanting to purchase new drives. I'm interested in using the Seagate ST2000DL003 2TB drives. These drives are not currently listed on the compatib...
mdgm-ntgr
Feb 26, 2011NETGEAR Employee Retired
You could either connect the disk to your PC (formatting it to use NTFS would be fine) and backup to it across your network, or put the disk in a USB enclosure and backup to the disk while it is connected to the NAS (for this you'd format the disk to use EXT3 under Volumes > USB Storage in Frontview and enable fast USB writes: http://www.readynas.com/forum/faq.php#How_do_I_improve_write_speeds_of_USB_External_Drive_attached_to_ReadyNAS%3F)
Before putting the disk you backed up to back in the NAS ideally you'd delete the partitions on it using a PC or at least ensure that it only has a single partition. Yes the NAS will automatically
You would need to backup the config separately. It'll backup your entire NAS config (not addons configuration though).
You would restore the config before restoring the data.
In the notes for 4.1.7 (http://www.readynas.com/RAIDiator_4_1_7_Notes) it says that a factory reset on 4.1.7 (or later once newer firmware is released) is required to setup the 4k sector alignment.
