jeffhayes
Jan 03, 2011Aspirant
ST2000DL003 Compatibility?
Being a RNP user that is running out of space, I'm wanting to purchase new drives. I'm interested in using the Seagate ST2000DL003 2TB drives. These drives are not currently listed on the compatib...
sjw
Feb 26, 2011Aspirant
Thanks - not quite sure about this bit - "Before putting the disk you backed up to back in the NAS ideally you'd delete the partitions on it using a PC or at least ensure that it only has a single partition.". Why would there be any partitions on the drive?
Is there a performance benefit backing up to an EXT formatted drive over USB than over the network to an NTFS drive (only 100mbps router).
Process I will follow:
EDIT: and is it the config backup that restores all of the user ID's passwords, share permissions etc?
- Attach 1st new HDD.
Backup to 1st new HDD.
Backup config to USB stick.
Remove both 1TB disks.
Put in 2nd new HDD.
Perform Factory Reset.
Restore config from USB stick.
Restore data from 1st new HDD.
(at this stage I may do a backup of the restored data from the NAS to one of the old 1TB drives - before adding the 1st HDD to the system)
Hot add 1st new HDD.
Pray.
