jeffhayes
Jan 03, 2011Aspirant
ST2000DL003 Compatibility?
Being a RNP user that is running out of space, I'm wanting to purchase new drives. I'm interested in using the Seagate ST2000DL003 2TB drives. These drives are not currently listed on the compatib...
mdgm-ntgr
Feb 27, 2011NETGEAR Employee Retired
SSH and all other addons you wish to use would need to be re-installed, with the possible exception of the addons included in the firmware (e.g. ReadyNAS Remote, though 4.1.7 ships with an outdated version of that, so it'd be advisable to update it to the latest).
If you have stuff on the OS partition you wish to backup, you may wish to create a tar archive of it (do one that preserves ownership and permissions, you can see a good example in the build_addon script you download from the article: How to develop a Frontview Add-on, the install.sh script shows how to unarchive it). It'd be up to you to find where the config for your addons is stored and back that up should you wish to do so. Best to note down what your settings are just in case you don't find all the files you need to archive.
Once you have your tar archive, copy/move that onto the C volume and then back it up.
