jeffhayes
Jan 03, 2011Aspirant
ST2000DL003 Compatibility?
Being a RNP user that is running out of space, I'm wanting to purchase new drives. I'm interested in using the Seagate ST2000DL003 2TB drives. These drives are not currently listed on the compatib...
sjw
Mar 05, 2011Aspirant
OK, the data copied off OK and I did a factory reset (when I restarted with the drive in it asked me which RAID I wanted - I went for the normal, expandable one). Restored the settings OK. My write speeds back to the NAS are slow - 11-12MB/s - over a gig network. My read speeds doing the backup (obviously on the old drive) were around 30MB/s. I didn't check the write speeds after switching to the gig switch.
This is going to take a looooong time.
I have just downloaded the logs and the partition.log file looks like this:
I could be totally wrong but what does the 'Units = sectors of 1 * 512 = 512 bytes' bit mean? Is that not where you would now see 4k?
Also, In My Computer on W7, the drive of the NAS (mapped to NAS 'c') says Filesystem - NTFS. That can't be right can it?
The smart+ for the drive says:
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 3906992335 1951192152 5 Extended
/dev/hdc5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
Disk identi
Spin Up Time 0What's with the head flying hours there?
Start Stop Count 6
Reallocated Sector Count 0
Power On Hours 3
Spin Retry Count 0
Power Cycle Count 6
G-Sense Error Rate 0
Power-Off Retract Count 4
Load Cycle Count 6
Temperature Celsius 33
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Head Flying Hours 6532645257219
ATA Error Count 0
