jeffhayes
Jan 03, 2011Aspirant
ST2000DL003 Compatibility?
Being a RNP user that is running out of space, I'm wanting to purchase new drives. I'm interested in using the Seagate ST2000DL003 2TB drives. These drives are not currently listed on the compatib...
mdgm-ntgr
Mar 05, 2011NETGEAR Employee Retired
You probably waited long enough. In any case doing the factory reset was probably unnecessary if the disk was new and hadn't been used before, but it wouldn't have hurt.
Comparing two disks in the NAS versus one isn't a fair comparison in my view. You also need to consider the performance differences between your new and old disks.
