NickHW
Dec 31, 2011Aspirant
ST3000DM001 Barracuda 7200.12 3TB
Any experience with these drives? I've just ordered some for my Ultra 6 Plus. Will provide feedback later on when they're delivered. I see the older Barracuda 3TB is on the HCL but not these newer mod...
mdgm-ntgr
May 31, 2012NETGEAR Employee Retired
Wirregar your NAS has shipped with RAIDiator x86 4.2.15 or earlier which does not support 3TB drives.
I'd recommend you install just one 3TB drive in the NAS, do a factory default (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu), update to the latest firmware, verify update is successful, then power down and put all the disks in and do another factory default. This will give you a clean setup on the latest firmware.
