Pilou29
Jun 05, 2015Aspirant
ST32000524AS - ST31000528AS - ReadyNAS 102
Hello, I'm asking this here since I haven't found the answer to my questions (sorry if I missed it!). I would like to know if it's possible to use with a ReadyNas102 the following Seagate hard driv...
Jun 05, 2015Guru - Experienced User
Those models are pretty old, and aren't on the RN102 compatibility list. You will probably be denied support if you use them. Though I suspect they will work.
"Connecting them together" is RAID-0 (so you are "trying to do a raid"). If you do that, then if either drive fails you will lose all your data. It is much safer to use "jbod". That keeps the disks independent, so a failure of one drive won't affect the other.
However, spanning RAID-0 is available in flexraid.
