Pilou29
Jun 05, 2015Aspirant
ST32000524AS - ST31000528AS - ReadyNAS 102
Hello, I'm asking this here since I haven't found the answer to my questions (sorry if I missed it!). I would like to know if it's possible to use with a ReadyNas102 the following Seagate hard driv...
Pilou29
Jun 06, 2015Aspirant
@StephenB: Thank you for your quick answer. I will do that and keep them separated in the NAS then. I will keep you updated on the matter!
@Ixa: Thanks, I had checked it before and didn't see them. Which is understandable as they are indeed pretty old now.
