yupsolo
Aug 04, 2011Aspirant
ST3250410AS 250gb
Got a readynas ultra2 and two of those HD. works perfectly
mdgm-ntgr
Aug 05, 2011NETGEAR Employee Retired
Those speeds are pretty good for wireless. The wireless would be the limiting factor. Accessing over gigabit ethernet you'd get much faster speeds.
You should note that there's no 250GB disk on the HCL. Whilst technically 250GB disks can work, if you run into issues with those disks NetGear will deny support. Still if you had a few of those disks lying around and backup important data primarily stored on the ReadyNAS regularly then I can understand choosing them.
- Nov 16, 2016Retired_Member
