aguden_guden_co's avatar
Aug 10, 2012
NV+ from 250GB to 8TB - best method
From reading the forums, I get the feeling that I have 2 ways to move from a single 250GB drive in my ReadyNAS NV+ to 4 2 TB drives.
1. Add the 3 drives and let the upgrade complete and reboot. Then swap the 250GB for a 2TB and let that synch and probably reboot.
2. Start from factory default and put in 4 2TB drives.
I have basically no data yet on the 250GB drive. One file to make sure I can see it. I have upgraded the firmware to 4.1.9 and completed all of my settings through Frontview/RAIDair.
Which would be best. #1 seems simplier. Do I get any gain in any performance bt doing #2?
Thanks
Al
  • StephenB's avatar
    I am not sure if you would see a performance benefit - that might depend on when you did your initial install (and what firmware you were running).
    Though since your setup is simple, and you don't have a lot of data to preserve, it is easiest to do the factory default. All you need to do is power down, and install all four empty drives. After the initial setup, reinstall any addons, reconfigure shares and any users, and you are done.
  • Thanks for the quick response.
    I have no data to preserve other than the one test file (good bye!) and the data from the setup. I have installed the latest firmware (4.1.9) and wondered if I backed up my setups from within Frontview could that be restored. I'd have to back it up with the 250GB drive and then restore it with the 4 2TB drives. Or should I just not complicate thaings and do a factory default and let it go from there?
    Al
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    If you want to backup your config do the following:
    1. Backup data
    2. Do System > Config Backup and keep the zip file.
    3. Note add-ons you have installed under Services > Installed Add-ons
    4. Do factory default
    5. Re-install any add-ons
    6. Restore Config Backup
    7. Restore data from backup
  • Ok. No add-ons so I can skip #3 & %. And after the backup I would power down and install the new drives. Then factory default in the power on cycle by holding the paper clip in the reset hole for 30 seconds. Once it comes to life, find the drive on RAIDair and sign in using the defaults. Restore the backup and then reboot. At that point I should be completely up to date!
    Or can I do a factory default from Frontview after I install the 4 new drives? Will RAIDair see the box with the new drives?
    Sound right. Just don't want to miss anything!
    Again. Thanks. I don't fool with an install/upgrade with these baoxes very often. One was purchased in 2006 and the only thing I've done to it is the regular firmware updates and replaced a power supply. The 2nd box was purchased in 2007 and Netgear replaced it when it went DOA a few years ago. This new (used) box is getting the works. Just did a memory upgrade (successful) and now the drives. So they just sit there and work for years at a time and it sure is great that this forum exists since Netgear won't help and even when I had one still in warranty, it took over a month to get replaced! Thank you.
    mdgm-ntgr
    I'd use the paperclip method to do the factory default, though if the only disks in the NAS are unformatted drives this should be done automatically.
ProSupport for Business
