aguden_guden_co
Aug 10, 2012Luminary
NV+ from 250GB to 8TB - best method
From reading the forums, I get the feeling that I have 2 ways to move from a single 250GB drive in my ReadyNAS NV+ to 4 2 TB drives. 1. Add the 3 drives and let the upgrade complete and reboot. T...
Aug 10, 2012Guru - Experienced User
I am not sure if you would see a performance benefit - that might depend on when you did your initial install (and what firmware you were running).
Though since your setup is simple, and you don't have a lot of data to preserve, it is easiest to do the factory default. All you need to do is power down, and install all four empty drives. After the initial setup, reinstall any addons, reconfigure shares and any users, and you are done.
