aguden_guden_co
Aug 10, 2012Luminary
NV+ from 250GB to 8TB - best method
From reading the forums, I get the feeling that I have 2 ways to move from a single 250GB drive in my ReadyNAS NV+ to 4 2 TB drives. 1. Add the 3 drives and let the upgrade complete and reboot. T...
mdgm-ntgr
Aug 11, 2012NETGEAR Employee Retired
If you want to backup your config do the following:
1. Backup data
2. Do System > Config Backup and keep the zip file.
3. Note add-ons you have installed under Services > Installed Add-ons
4. Do factory default
5. Re-install any add-ons
6. Restore Config Backup
7. Restore data from backup
1. Backup data
