Laserbait's avatar
Laserbait
Luminary
Jun 08, 2017
ST4000DM005 not on the HCL
Why is the ST4000DM005 not on the HCL yet?  Has it proven to be incompatible?
  • StephenB's avatar
    Likely it's not a priority, since it's just an updated ST4000DM000.  Though I'd choose an Ironwolf 4 TB over the DM.
    • Laserbait's avatar
      Laserbait
      Luminary
      You're probably right, but when I see Netgear doing this with other disks: "This disk should be compatible based on the test result of another disk in the same series from the disk manufacturer." it makes me wonder.
ProSupport for Business
