doug714
Oct 14, 2020Aspirant
Storage available isn't close to HD capacity
I have a readnas 202 with a 4TB drive (WD40PURX) and a 3TB drive (WD30EFRX). After setting up the readynas it shows both drives online with the 4TB drive in the first bay and the 3TB drive in the se...
- Oct 14, 2020
The only redundancy possible (being X-RAID or a RAID1) is using 2 * 3 TB, ... that makes about 2.7 TB net. Perfectly correct.
schumaku
Oct 14, 2020Guru - Experienced User
- Sep 02, 2016Retired_Member
