euphos
May 30, 2015Aspirant
Storage Calc RN104
I'm migrating all my drives from one RN104 to another RN104 due to having to RMA the unit. Since the drives were all installed when the original unit cal with OS 6.0.0, I want to do a factory reset w...
vandermerwe
May 30, 2015Master
viewtopic.php?f=24&t=78891
Use this volume calculator:
http://ram.kossboss.com/xraid/
On the 104 there is a 16Tib volume size limit.
...and you would get volume expansion with the upgrade of the 3tb to 4 or 5tb disk. If you used a 5 TB then you would get further expansion if you replaced on of the 4 tb disks with a 5 tb disk.
