euphos
May 30, 2015Aspirant
Storage Calc RN104
I'm migrating all my drives from one RN104 to another RN104 due to having to RMA the unit. Since the drives were all installed when the original unit cal with OS 6.0.0, I want to do a factory reset w...
Jun 01, 2015Guru - Experienced User
Frankly most users don't even know the compatibility list exists.
mdgm wrote: Well 4x5TB in a spanned RAID-0 is above the limit.
Some users choose to ignore notes we put on the compatibility list.
These disks work, and you can't actually get to the 16 TiB volume limit unless you use disks > 4 TB. I think its wrong for Netgear to deny support on the RN100 when these drives are appropriately used. And that's what happens if they aren't on the HCL.
