euphos
May 30, 2015Aspirant
Storage Calc RN104
I'm migrating all my drives from one RN104 to another RN104 due to having to RMA the unit. Since the drives were all installed when the original unit cal with OS 6.0.0, I want to do a factory reset w...
mdgm-ntgr
Jun 01, 2015NETGEAR Employee Retired
A link to the list is specifically mentioned in the hardware manual and in the installation guide.
If you are looking to use 6TB disks you really should consider the 200 series and up.
The volume capacity limitation is one reason 6TB disks are not on the compatibility list for the 100 series. There may be others.
