holsen1's avatar
holsen1
Straight Upgrade From ReadyNAS NV+ ?
Well My ReadyNAS finally Blew.  It wont power up so I'm assuming its a PSU Failure but here's my question.  I've 4 x 2TB drives in there and as opposed to Jerry Rigging a PSU to fire it up and migrate I'm wondering (hoping) there is a unit I could just pop the drives into and pick up where I left off.....  suggestions?    Thanks!
  • The only drop-in replacement capability is from another NAS of the same model, which would likely be as old as yours, if not older.  Take a look at what I just told another user asking a similar question: DATA-FROM-FAULTY-NAS
    • holsen1's avatar
      holsen1
      I found a new PSU, and put it in and the old girl fired right up,  but now my cooling fan is spinning so fast its putting out a a high pitched whine I can hear 3 rooms away.   The Old PSU was 95 Watts, the new one is 350 Watts.   Could that be the cause.   DO you know if there is a setting somewhere to dial back the fan?
      Thanks
      • Sandshark's avatar
        Sandshark
        Sensei
        The rated wattage of the power supply makes no difference as long as it is at least as high as the original .  The unit will draw what it needs and no more.
        Does you replacment supply have the small attached fan?  If so, that's your culpret.  The small size makes for a high-pitched whine.  If that's not it, then you need to do a fan calibration.  It's been a while since I used a RAIDiator 4.x based system, but it's in the menu somewhere.
        The original NV had the small power-supply fan, and Infrant (later acquired by Netgear) replaced it with the fanless one because of complaints on the whine.
ProSupport for Business
