SLK-Purdue
Sep 22, 2020Luminary
Strange issue with migration from 102 to 312
I updated from a ReadyNAS RN102 to a RN 312. I moved the volumes as detailed in the instructions. Everything worked great and the new unit came up just fine.running 6.10.3. (Nice improvement in ...
- Sep 23, 2020
Sandshark wrote:
It sounds to me that PHP5 was remoevd, but this file was not: /etc/apache2/mods-enabled/php5.load. I'm not really versed in how apache uses such configuration files, but I think it automatically runs anything in that directory, there is no poiner to the file elsewhere that you also need to remove. Try just moving that file to a holding area and see what happens.
Since it works in the RN102, /usr/lib/apache2/modules/libphp5.so wasn't removed either (and is the arm version of the library). So PHP5 wasn't fully removed.
Still you could simply move php5.load. Make sure there's no php5.conf in the folder either. Also, you should look at the libraries php5.load is loading, and move them to the holding area also.
Lines 200, 201 in the apache2.conf are
200 IncludeOptional mods-enabled/*.load 201 IncludeOptional mods-enabled/*.conf
So you don't actually need to edit the conf file.
Still,I'd do the factory reset (painful though it is) if it were my own system.
Sep 23, 2020Guru - Experienced User
It looks like you failed to uninstall your apps. While the NAS can convert it's core functions from arm to x86, it can't convert third party apps.
In your case, at least one of the apps uses php5.
Options are to
- do a factory reset, reconfigure the NAS, and restore from backup.
- try putting the disks back into the RN102, and migrate back. Then uninstall the apps, and try again
I guess you could also try uninstalling the apps now (either from the web ui or from ssh) - no idea if that will work or not.
Definitely make sure you have a backup, no matter which option you attempt.
SLK-Purdue
Sep 23, 2020Luminary
First, thanks.much.
I was pretty sure that I uninstalled but I have now migrated back to the 102 and confirmed that all apps were uninstalled. What points you to php?
I am back running fine on the 102. Any other thoughts? Seems the issue is somewhere in the change for arm to x86. I really want to get the the 312.
Scott
StephenB wrote:
SLK-Purdue wrote:I updated from a ReadyNAS RN102 to a RN 312. I moved the volumes as detailed in the instructions.
Options are to
- StephenBSep 23, 2020Guru - Experienced User
This log entry you posted:
Sep 22 18:21:00 NAS-Ksander-2 apachectl[23934]: apache2: Syntax error on line 200 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/mods-enabled/php5.load: Cannot load /usr/lib/apache2/modules/libphp5.so into server:
/etc/apache2/mods-enabled/php5.load and /usr/lib/apache2/modules/libphp5.so don't exist on a stock OS-6 system, so php5 was installed by an app. Given that you did uninstall the apps, it sounds like one of your apps didn't remove php when it uninstalled.
Well, I gave you the options that I see. You could do the factory reset and restore the data - that is best done on the RN312, not the RN102. That also gives you a fully clean install (and if the RN102 is old, it likely will give you better performance).
Or you can attempt to uninstall php5 on the NAS using ssh. You'd log in as root, using the NAS admin password.
A command that might do it is
apt-get autoremove --purge php5
I say "might" because I haven't actually run this myself. As always, you use ssh at your own risk.
If it does complete successfully, then reboot the RN102 just to make sure the web interface works properly before you move back to the RN312. Maybe also check that the two files above are gone.
- SLK-PurdueSep 23, 2020Luminary
Again, thanks much.
I can believe that but not sure where to go from here. Is it safe to try to uninstall php5 at the Linux level with apt?
apt list | grep php - does show php5
apt list --installed | grep php - does not show php5
Thanks,
Scott
This is of course some risk, especially if you can't use apt - which might be the case if stuff was left behind by a previous uninstall. Hence the repeated suggestion to make a backup. If you have a backup, then it were me, I'd do a factory reset on the RN312 instead of migrating, and start over clean.
If you can't make a backup, then maybe get a new disk for the RN312, and keep the RN102 running - repurposing is as a backup NAS. Then add a second disk to the RN312 when budget permits.
A variant here (again has some risk) is to remove one disk in the RN102, and do a factory reset with that disk in the RN312 (leaving the RN102 degraded). Reconfigure the RN312, and use share-by-share backup jobs to migrate the data to it.
Once it is set up, you can either do a similar reset on the RN102, and back-haul the data back to the RN102 from the RN312 (allowing you to use the RN102 as a backup NAS), or you can move the remaining disk to the RN312. IMO using the RN102 as a backup NAS with jbod volumes on both NAS apt liis better than using RAID-1 on one NAS.
