webmister
Oct 05, 2020Aspirant
Streaming from ReadyNAS without password
Hi all :) I work in a small staff (7 persons). We analyze sport videos with a dedicated software. This software basically opens a video file. As we have tons of videos to store and share, my...
Retired_Member
Oct 08, 2020Using \\<network>\ locations are good for LAN's (speed), and as mentioned above over the internet using VPN, however since VPN adds another layer and over the internet, there may be speed issues playing video without pauses.
There are also other solutions to accessing the NAS over the internet as a local drive, SFTP/FTPS is another (using s/w like mount SFTP Drive, etc.) - that way you can mount via SFTP/FTPS as long as the passwords are good enough. This may has have speed issues/pauses with playing video, but FTPS/SFTP may be better that VPN for transfering over the internet, it depeneds on the s/w used.
There are other methods to access (read only) video's that's also accessible over the internet, like running a media server (Emby, Plex, Kodi, etc.) - some of these (Emby/Plex) tend to transcode the quality depending on the speed of the connection and usually have their own interface (webpage based), so playing them through custom s/w may not be viable.
All in all, you would need to test the speed of transfer, esp for FTPS/SFTP type of mounted drive. SFTP/FTPS will give full access unless you have setup read only access on the NAS. I believe you can enable FTPS (via FTP + Security enabled) with such security, however I do not believe OS6+ has yet to implement account security with SFTP (via SSH). Both settings are in the NAS Front-view settings page. I do not recommend SFTP (via SSH), since it potentially gives full access to you NAS for anyone using it. From memory, I believe at least with FTP (Secure) you can setup read only access to the drives - but FTP on OS6+ has issues with PASV mode, etc. behind f/w routers, etc. and no settings to control/fix them.
If you can cater for it and don't mind the transcoding features of the media options, this would be the safest way to play videos as its independent of NAS access and also just to play videos. Also videos adjust according to the speed of the playing end, so buffering/stuttering shouldn’t be an issue. However, warning - you MUST get a decent CPU on the server running the media server to transcode videos, or it'll be painful.
Hope this helps further
Oct 08, 2020Guru - Experienced User
FWIW, if I were looking to solve this problem I'd also look at using cloud storage (onedrive or google drive). Though there is a monthly charge for that, it wouldn't require any hardware investment. It also would be easier to manage, and wouldn't require as fast an internet connection in the main office.
Whether Cloud storage is cost effective depends on the amount of storage you are talking about. 2 TB of google drive storage currently costs about $100 per year.
Though in the bigger picture, there can be operational benefits in consolidating storage with a NAS. It can simplify backup (and if webmister's firm doesn't have a good backup strategy in place now, they really should).
I don't know what you mean here, as both OS 4 and OS 6 allow you to set the passive mode port range. I've used both over the internet, and not run into any issues with passive ports.
There can be issues with masquerading when using FTP for both local and over-the-internet access. Those can be overcome by FileZilla, WinSCP, or other clients that have workarounds for that problem. I don't think the masquerading challenges are flaws with the ReadyNAS implementations, they are fundamental to the way the masquerading hack works.
FTP/SFTP/FTPS is an unusual protocol for streaming. You'd need to download the full video for playback if you use that (or modify the software they are using to include native support for FTP streaming). I've only run into one program that uses FTPS as an actual streaming protocol, and honestly it didn't perform any better than using OpenVPN. In fact, it performed somewhat worse.
"Adding an extra layer" doesn't directly affect speed, though it does add a bit of overhead on the wire. Encrypting the VPN link does add some compute overhead, and if the router isn't up to it that could limit the transfer speed. But that isn't usually an issue today, as most routers have hardware acceleration for AES encryption (especially if they also do wifi).
More likely the internet speed will be gated by webmister's ISP service, which is why I've asked about that a couple of times now.
Overall, a VPN is more likely to be secure than using protocols that require a lot of port forwarding, especially in a scenario where there isn't a dedicated IT person with the appropriate skills. It also gives folks full access to the office network (allowing remote printing, among other things).
It'd be useful to know if switching to other software is an option or not. I've been assuming that webmister wants to continue to use their current application software, and it sounds like that currently directly reads the files from the disks. If that's the case, then they would need to stick with SMB as the file protocol (or download copies of files to local drives first). Either approach takes those other streaming solutions off the table.
Plex definitely needs it's own app. Although the plex server does support DLNA as well, that won't work over the internet. I haven't used Emby or Kodi.
As far as real-time transcoding goes, I don't think there is any ReadyNAS that can handle transcoding of 7 simultaneous HD streams, and none can handle transcoding of multiple 4K streams. If that is needed, you'd need to pair a high-end PC with GPU acceleration with the ReadyNAS.
- Retired_MemberOct 12, 2020
It wasn't really addressed to you, so not sure why your answering my post? Anyhow, the fact is there are few options to configure FTP using the OS 6 Frontview - its pretty crap. Active Vs PASV option doesn't exist and PASV ports are determined by the server not the client etc. which also require firewall, routing etc. and can have potential masquarading issues... not interested in hijacking this thread about the inadequences of OS 6, just to make the OP aware of limitations with the option suggested with the limitations of configrationabilty of the interface.
Retired_Member wrote:Using \\<network>\ locations are good for LAN's (speed), and as mentioned above over the internet using VPN, however since VPN adds another layer and over the internet, there may be speed issues playing video without pauses.
Again I'm not here to explain things to you, only to provide options to the OP and if the OP wants to persue the option, questions can be asked, etc,.
The videos don't need to be 'fully downloaded' before starting to play - that depends on cient-side player. I didn't mention anything about streamin protocols - these have other limitations, pro's and con's.
Again depends on the s/w used and options available..
Retired_Member wrote:There are other methods to access (read only) video's that's also accessible over the internet, like running a media server (Emby, Plex, Kodi, etc.) - some of these (Emby/Plex) tend to transcode the quality depending on the speed of the connection and usually have their own interface (webpage based), so playing them through custom s/w may not be viable.
When you talk about streaming protocols, your introducing 3rd party s/w on the server side. Which means one would look at seperate hardware anyhow - I did not say nor suggest using the NAS to do streaming with 3rd party s/w, only to provide alternative options to the OP.
Either use the NAS as a storage unit and directly access it via LAN-Type access OR use it as a storage unit and use 3rd party media s/w to serve the media (stream, transocde, etc.).Its up to the OP to determien their own setup and whatever matches their needs. The OP asked for suggestions and options without any info on their setup - so suggestsions and options where given.
