brendan87's avatar
brendan87
Supported Drive wont physically fit inside my readynas204???
I paid a little more to get the 'Seagate ST6000NM0024 6TB SATA drive' because it was on the compatible drive list (link at bottom) and it wont physically fit inside my readynas 204 (RN204). The hot...
  • StephenB's avatar
    Oct 08, 2015
    The WD60EFRX does not have this problem.
ProSupport for Business
