brendan87
Oct 06, 2015Aspirant
Supported Drive wont physically fit inside my readynas204???
I paid a little more to get the 'Seagate ST6000NM0024 6TB SATA drive' because it was on the compatible drive list (link at bottom) and it wont physically fit inside my readynas 204 (RN204). The hot...
- Oct 08, 2015
The WD60EFRX does not have this problem.
brendan87
Oct 08, 2015Aspirant
You are right. I guess just don't like having to undo screws. So. .. I ah got out my drill and made two holes in each side of the drive. It's tool-less now, seems to work just fine. Goodbye warrantie
