brendan87
Oct 06, 2015Aspirant
Supported Drive wont physically fit inside my readynas204???
I paid a little more to get the 'Seagate ST6000NM0024 6TB SATA drive' because it was on the compatible drive list (link at bottom) and it wont physically fit inside my readynas 204 (RN204). The hot...
- Oct 08, 2015
The WD60EFRX does not have this problem.
brendan87
Oct 08, 2015Aspirant
Does anybody know of a 6tb drive that won't have the same problem that's on the compatibility list. I buy the drives online and they all have the same picture so I can't tell which ones will fit in tool-less
Oct 08, 2015Guru - Experienced User
