brendan87
Oct 06, 2015Aspirant
Supported Drive wont physically fit inside my readynas204???
I paid a little more to get the 'Seagate ST6000NM0024 6TB SATA drive' because it was on the compatible drive list (link at bottom) and it wont physically fit inside my readynas 204 (RN204). The hot...
- Oct 08, 2015
The WD60EFRX does not have this problem.
brendan87
Oct 08, 2015Aspirant
Does anybody know of a 6tb drive that won't have the same problem that's on the compatibility list. I buy the drives online and they all have the same picture so I can't tell which ones will fit in tool-less
RNASguy
Oct 31, 2015Luminary
I just installed 6 Western Digital Red Pro 6TB drives model # WD6001FFWX. They work just fine with the tool-less plastic part on the drive sled.
However, even though it works tool-less I always put in one screw to be sure it won't slip out. When releasing the sled from the NAS, if you hold down the Recessed disk tray handle locking mechanism as you pull out the sled, the drive will be released from the sled and possibly fall. This happened to me when the tool-less sled was a new item.
Ever after I went the belt and suspenders route and put in one screw.
hope this helps
bc
