mhellstrand
Feb 05, 2014Tutor
Swap disks between readynas units.
Hi! Is it possible to use disks from an existing RND2000 Duo V2 system (data on the disks) in a Netgear ReadyNAS 102 2-Bay NAS? To my knowledge they have the same CPU architecture? (Marvell ARM CPU ...
Feb 06, 2014Guru - Experienced User
Although I haven't tried it, I've seen posts here that say you can migrate between RN1xx and RN3xx/Rn5xx. Apparently the new NAS does an OS reinstall, and the file system is preserved. Not sure what happens to apps.
Apart from that possibility, these lists look correct to me.
