davidr1's avatar
davidr1
Luminary
Feb 19, 2016
Swapping disk sets between units
Software version: 6.4.2   I have: NASPro with 2 x 1TB drives NASUltra with 2 x 2TB drives.   I would like to retain the data on both but move the Pro's 1TB drives to the Ultra and the Ultra's 2...
  • StephenB's avatar
    Feb 20, 2016
    davidr1 wrote:
    ...then I want the shares that were on the ultra to go back to the ultra and the shares that were on the pro to go back to the pro.
    To accomplish that last step you need to
    (a) create the (empty) shares on the pro that will end up on the pro
    (b) use the web-ui backup to transfer those shares from the ultra to the pro
    (c) delete the "pro" shares on the ultra, and create the (empty) shares you want on the ultra.
    (d) use the web-ui backup to transfer those shares from the pro to the ultra
    (e) delete the extra shares on the pro.
    This implies that the pro can hold all the shares from both machines.  If not, you will need to either offload to external storage, or try to "shuffle" one at a time.  That is for share A on the ultra, and share B on the pro:
    (1) create share A on the pro
    (2) copy share A to the pro
    (3) delete A from the ultra
    (4) create share B on the ultra
    (5) copy share B to the ultra
    (6) delete B from the pro
    ad nauseum...
    What happens to file/group owners depends on how the UIDs and GIDs are assigned.  Ideally you'd have exactly the same users/groups configured on both machines - then rsync would preserve ownership and permissions.  If that's not what you have now, then you might have some permissions/ownership cleanup you'll need to do at the end.
ProSupport for Business
