tony359
May 09, 2014Apprentice
Switch advice please
Hello, Having verified that my Virgin Media 'Super Hub' is not the best as a switch, I was thinking of getting a decent one which I may use for some years when/if my network expands. I like the ide...
tony359
May 11, 2014Apprentice
Thanks xeltros.
The maximum managed speed is a good point. I did not know that.
The GS716T-200 has 32 Gbps, which is a good thing. I will definitely check this in the future, thanks!
Stephen,
while searching, I've come across the below:
It appears there is a fan then?
Stephen,
It (v2 and 200) has many more features and is more up to date than the v1 model and the nicest feature for me is that this model has only one fan which is a lot more quiet than the two fans I heard on the v1 model. The v1 sounded like a hair dryer set on low speed, this model puts out a whisper and is no louder than a whirring fan of a quiet desktop PC.
