tony359
May 09, 2014Apprentice
Switch advice please
Hello, Having verified that my Virgin Media 'Super Hub' is not the best as a switch, I was thinking of getting a decent one which I may use for some years when/if my network expands. I like the ide...
May 12, 2014Guru - Experienced User
I don't see 802.31ad or LACP listed on the GS116E datasheet (http://www.netgear.es/images/GS116E_DS_ ... -16292.pdf)
fastfwd wrote: As far as I can tell (I don't use it), their "port trunking" is 802.3ad Link Aggregation; I think that's supported by the ReadyNAS Pro. Port trunking is not available on the GS108E, but the GS116Ev2 (part number GS116E-200xxx) does support it.
