tony359
May 09, 2014Apprentice
Switch advice please
Hello, Having verified that my Virgin Media 'Super Hub' is not the best as a switch, I was thinking of getting a decent one which I may use for some years when/if my network expands. I like the ide...
May 12, 2014Guru - Experienced User
The GS724T datasheet specifically calls out 802.3ad. I don't see either 802.3ad or 802.1ax in your newer datasheet either.
tony359 wrote: Well the smart switches' datasheet mentions port trunking. There must be something but I can't find an exact reference.
802.3ad is supported by all the smart switches, does that say anything?
Port trunking implies link aggregation, but it doesn't necessarily mean LACP - it could be proprietary.
